naysjp
Read the write up on changing differential fluid. Very good as I changed the front differential. Tried to do the rear but unable to remove the rear fill bolt. The front came off just fine without using the 3" ratchet extender so I used it on the rear to see if that would help, no go. Any reason why there is an issue? I expected the concept to be the same as the front differential. Read the article several times before I started. Trying to do more things myself instead of giving the dealership $90 to suck out the old fluid and put in new fluid.
