TSB 08-074-20....steering
MericaMade
I changed out the front trackbar, draglink and tie rod with Steersmarts, the Synergy Sector Shaft brace and a Fox SS. The dealer called my Jeep “heavily modified”.
I just reopened a case with Jeep Cares, because someone told me to look into the Magnuson-Moss Warranty Act. I looked at it, and the way it reads, the dealer would have to change out the steering gear. We shall see.
Remove the sector shaft brace. You can't expect them to remove it.
Ddays
Just had the cast iron box installed this past week. Now my JL has developed an annoying wobble at exactly 37~41 mph. Nothing below or above. :mad:
Gonna check all of the torque specs this weekend.
DaveL
Reflash
Heard that if the dealer doesn't re-flash the computer there are problems with this update. Slop on centre. May be other issues.
-AINOKEA-
Got this done yesterday. Steering feels much better. They also flashed the computer for something with steering and another “required” pcm flash. Throttle feels a little more responsive and smoother. I forgot to take out my tazer before dropping it off so hopefully it didn’t dry anything.
jeeeep
did you get it figured out?
JKbrick
I wonder what the computer has to do with the steering? I need to call the dealer that did my son’s TSB because I don’t believe his got flashed
Sessoms14X
So after driving a couple trips in my JT I will say that I do notice a difference. Seems to wonder a lot less on the highway (70mph). Don't have to correct the steering wheel as much. Has a tighter feel.
Even from a sharp turn the steering wheel will return back to center easier. So I will say that I'm happy with the fix.
Does anyone know if this has been addressed at the factory yet? Any dates that a change has been made to new builds or are they still cranking out the defective steering?
From my experience on other vehicles, when a part is updated, production from that point forward uses the new updated part. Hope that is the case in this situation.
cozdude
Guy with a Red 2-Door
What Doug said. They will already be on new vehicles coming off the line. From my understanding all 21 models should have them
jeeeep
I was looking at newer models while my JL was in service and the models I looked at had the newer box.
bkac
They are being installed on the new vehicles from the factory. The bolts on the frame side of the old box are silver, the new updated box comes with black bolts. It’s a very quick way to tell if it has the new box in it.
Sweet!
Awesome!
Thanks
bkac
I actually picked up a new spare box yesterday. You can see the new bolts in this picture.
DaveL
Does anyone have a copy of TSB 08-003-21? Curious as why they completely changed the TSB number instead of just a revision "D,E, etc' as they have done in the past...
I tried to copy the new TSB and paste it here. No luck.
