Transmission leak.
Colorado4
08 Jeep Wrangler JKU
I'm back, new adventure this time. Overnight 3x4 inch stain on driveway.
Driver's side, above the pan towards rear of jeep, about 5 inches up it is wet with trans fluid.
I am assuming its a seal but I wanted to bounce it off of you guys.
Last week I had the range sensor replaced, however I have had no leaks until now. Exhaust manifolds were replaced same day the leak started, don't know if that matters.
Any thoughts?
jeeeep
transmission lines on the JK are notorious for leaking at the compression fitting. The issue I found when replacing mine, the hose to too large for the tubing.
are you sure it's the transmission line? The transmission line runs from the radiator cooler to the transmission, no further back
CalSgt
If you had work done last week take it back and have them look at it, if its their fault ask that they make it right. If its because of worn out old parts I'm sure they'll give you an estimate and explain the issue.
