mudmobeeler
1. There is no way that this tire on a full sized truck would EVER track like that - or they would no longer be in production. I've owned this tire in many different sizes with no issue.
[/B]
Happens more than you think.
[/B]
2. I will post the number as soon as I have it on each Wrangler. I have a feeling we all need to add or remove caster, being that we all added tire size.
3. I'm not the one complaining about it, as I don't drive far - or often. The wife and the coworker are the ones complaining. It was "so bad" that on a 5 hour road trip, he had to stop and take a rest because it was tiring constantly feeding steering input.
I'm looking for constructive help, not cheeky tough guy responses.
Our problem was that we had no issue on 285/70/17's. On 315/70/17's in the same make of tire - the issues started.
Think you've answered your own question.
funny how people add wider tires and expect them to be the same as stock tires. :crazyeyes:
Well that escalated quickly... Apparently keyboard tough guys can be found ANYWHERE there is an internet forum.
And it's called "tramlining".
Apparently when driving a Jeep, handling like a bucket of shit is "a wayalife"
Thanks to those who helped.
:beer:
:beer:
Also, if I am reading everything correctly, the Duratracs are mounted on factory wheels. The minimum rim width approved by Goodyear for the 315 is 8.5", however, the factory wheels are 7.5".
Not only will a wider than stock tire track differently, it not being mounted on the correct wheel will compound the problem.
:beer:
:beer:
:beer:
I want to see a video. I want to see how badly these Jeeps are tramlining....
WTF is tramlining?
WTF is tramlining?
WTF is tramlining?
from Wikipedia:
For the rail-borne mode of transport, see Tramway (industrial).
Rain grooved road that can cause tramlining
Tramlining is the tendency of a vehicle's wheels to follow the contours in the surface upon which it runs. The term comes from the tendency of a car's wheels to follow the normally recessed rails of street trams, without driver input in the same way that the train does. The same effect is sometimes called Nibbling.
Tramlining can usually be blamed on tires, and its incidence depends greatly on the model of tire and its state of wear. Although not normally dangerous, at very high speeds it can become a source of instability.
Vehicles with large and wide low profile tires are more prone to the effects as well as vehicles which have wheels fitted that are larger than the manufacturers recommendation or have reinforced sidewalls. People who are relatively inexperienced with driving with this tendency will feel that they have to make continual course corrections and it is very easy to overcompensate the steering, which could potentially lead to veering off the road especially if the road is a narrow track/country road.
The effects of tramlining can be eased by subjecting the vehicle to an inspection and calibration of the wheels (i.e. a full geometry check) or replacing the tires with non-reinforced (soft sidewall) tires.
:beer:
