Just curious, is TR the only beadlocks offering that backspacing?
I'm pretty sure Hutchinson rock monsters you can get in the BS if not damn close.
Can't agree more about the ease of install. These took me about 30 mins each with 40" nittos versus 45-50 mins each with kmc machetes and coopers.
I really like these a lot just can't wait to see them on the Jeep!
Well that's interesting... I haven't seen Trail Ready BL's in person up close yet. I just assumed that any aluminum wheel that had a bolt going into it via a gorilla (that's me!) turning it would have a replaceable insert for said bolt. [emoji848]
I'm looking to start my install next weekend and had a quick question about TPMS sensors. I'd like to still be able to see the PSI in my tires, I like that feature, so I was wondering if you think I could make that work or give up on that dream? I know a guy locally is running his OEM sensors and valve stems but he is running the small rings and I ordered the larger rings. . Whats your thoughts? Thanks!
Btw...this thread is going to really make the install easier so I appreciate your write up!
Didn't we go over this already?
View attachment 275216View attachment 275217
I'm pretty sure you are supposed to stand in th line of roll when servicing tires. I know a beadlock/tire combo for a jeep probably isn't gonna have enough pressure to really do much damage, but I've seen plenty of aircraft wheels blow out sideways.
Sent from my SM-G955U using WAYALIFE mobile app
That looks really sharp in red like that - nice job :thumb:
You'd be surprised at how many aluminum bead lock wheels don't have inserts. Even with inserts, you need to be careful with torque as you can spin them as well. The bigger concern is galvanic corrosion and that is why it is important to use zinc plated bolts.
Would you recommend applying anti-seize to the Chamber II bolts during installation?
Uh oh, I put a small dab of anti seize on the bolts on my slabs
Cindy and I recently installed an all new Dynatrac XD60 front axle in a 72.5" with PRO 1550 steering knuckles but to take advantage of all the benefits this new setup has to offer, we needed to run 40" tires mounted on wheels that have 5.5" of back spacing. Needless to say, we picked up a set of Cooper Discoverer STT Pros in a 40x13.50R17 and decided to run them on Trail Ready Beadlock wheels which are offered in an 8 lug bolt pattern and with the 5.5" of back spacing we needed. In this short write-up, you'll get to see just how easy it is to get everything installed and using basic tools.
Nice write up, thank you.
I just ordered the same on a set of PR60s. What size lugnuts did you use? I ordered the 2" long lugnuts and they appear to snug the rim tightly, however would like to go with a longer lugnut, maybe 2.5"+. Would like to know what lugnuts you are running on your wheels/axle combo. Thanks!
You have to keep chasing the bolts in a circle until they do
I tried 2" lugs with the same combo and they wouldn't work, had to move to 3".
