Very heavy and loud tire but also heavy duty.
Really ? my tires are the loudest tires I have owned except for a set of Boggers. Are you talking about MTs?
I know a lot of people put 35's on stock rims and I just put 285/75-17 on stock rims but you are looking at a much wider tire. I think Toyo recommends at least an 8.5" rim as that is like a 35X13.5 tire or there abouts. For sure going to need wheel spacers. I have 1.5" spacers and with mine I have about an 1.5" clearance up front and back about 2" so you will be close I bet.
My Toyo 35 MTs are the quietest MTs I've ever owned. And, even more importantly they perform very well off-road. You'll be quite pleased with them.
I started mine at 28psi and adjust as necessary.
Artec C gussets welded on.
WOW! those sway bar extensions are pushed way to the side... do you have them installed correctly?
Axle in the picture is at full droop with trackbar attached so thats the direction the axle gets pulled in. At ride height the links are perpendicular to the ground. This is why you install links on the ground or without the trackbar attached.
Ahhhhhh now I see it..... My mistake
How are you liking the 285/75s? I am considering these over the 35s as well. Viewed side my side unmounted they seem very close in height. How do yours measure mounted?
I like them a lot. did a lot of snow wheeling today and were incredible. They measure exactly 33" mounted on jkur with 30psi.
