Forgot mileage... 500.Haven't seen these on here yet...
Nitto Ridge Grapplers 35x12.5r17
Measured 33 3/8"
Gonna go 37's now. Damnit![emoji35]
Sent from my SM-G930V using WAYALIFE mobile app
On the narrower wheel it will pull sides walls in more thus curbing the tread pattern down. So when measured at the outside lug it would be slightly shorter. Where as the wife wheel will not pull the side wall in as much do the tread pattern should be more level. Now I could be wrong so just take that with a grain of saltI have seen it asked twice and hinted at once in this thread with zero response, so I am going to ask:
How valid is this dataset when rim width is not taken into account? It's good info, but wouldn't a 33x12.5 tire be taller on a 7" rim vs an 8" one?
sent from your basement
Nitto Trail Grappler 23,000 miles
37x12.5x17
35.25 in
I'm very interested to see how my wear compares to others.
How do tire companies get away with this isnt this false advertising?
27 1/2Cooper Discoverer STT Pro M/T
Size Stated on Sidewall: 225/75R16
Actual Height: 28-7/16" with about 3000 miles
And that was measured at 30 psi.Mickey Thompson Baja Mtz's with roughly 10,000km/6,250 miles. Size: 33×12.5R17 LT Measures at 31 1/4 inches.View attachment 240890View attachment 240891
Sent from my SM-G900W8 using WAYALIFE mobile app
No lift. Backspacing is 5.20 and no rub issues.How much lift are you running? Do you get any rubbing? Those wheels only have 5.12" of BS don't they.
Probably no rub because it can only do little Jeep things.How much lift are you running? Do you get any rubbing? Those wheels only have 5.12" of BS don't they.
