Steering
Xjproject417
Xj has steering problems I have to rev it up to get power steering to kick in not sure if pump is bad or just have air in it any solutions?
With fluid full, turn the steering wheel back and forth 4 or 5 times to bleed air out. Any leak in the system can continue to suck air in though. Also, check belt tension. If belt is slipping, that will create the same symptom as a failing pump. If all of that is ruled out, it's probably a bad pump.
