Indy14jk
Ok so i have read tons here and there about the death wobble.. Which is what i DO not have....
I changed from 20x10's with 33's to 22x15 with 37's... And has a 6" lift. Both sets of tires have been on with the lift.....
No with the 37's
between 35-40 the steering wheel has a slight left n right motion and after 40mph it goes away. My tires were set to 38psi after being mounted and balanced.. I read that most drop to between 28-30 psi with 37" tires. I tried that and it was lil worse. So i reinflated back to 38. Not as bad
Just wondering if it the balancing of the tires? Or possibly that my sway bar disconnects are set to much lenght?
I noticed the other day that the threads are pretty well almost out all the way. I looked up install on it and says that from top to bottom they should be 11". Mine are set at 11.5" from hole to hole. Would that put to much pressure on the sway bar to cause such a issue? Because it was fine with the 33's?
Just wanna make sure it is all right before i start looking elsewhere
And my jk is new and has 5k miles on it so i dont think i could have any bad ball joints
No with the 37's
