Run2jeepn's JKU Build
run2jeepn
Cool, good to know. Got a set for my super duty axel.
I ran into a small clearance issue. They said it happens with about 5% of the JKs. I've got to shave a little from my Outer yoke and a little from the lower nut. Not a huge deal
Went to bolt on my Front Track bar mount. ran into an issue there too. The last owner reinforced it by adding a plate to the outside. Which I have to grind off before I can mount it.
Once I get these 2 things done. The axles should be ready to install. Would have done today, but we had to paint a Car in the shop today. So no grinding today.
run2jeepn
Got my Motobilt Rockers painted and ready to install.
Tried to get my Tierod finished today. Welded the Bungs on and one warped on me. So I've got to cut it off and already ordered another.
run2jeepn
Swapped Radiators. Got rid of the junky Mishimoto one for an OEM Replacement.
Pic of the Rockers painted.
Cut the Tierod Bung off and ordered a new one. Should be here Tuesday.
Spent a good hr cutting and grinding to get the extra plate of steel welded to my factory track bar mount off.
