cozdude
Guy with a Red 2-Door
Did that actually make a difference?
It did. No lifter tick on cold starts anymore.
Interesting. I'll give that a shot next oil change. Assuming I can just add it to the old oil before swapping it out or should the oil be clean and do the change twice? ATF+4 is fine or something else?It did. No lifter tick on cold starts anymore.
If prefer not to change the oil twice.I work in the service department at a GMC dealer and used the ATF we put in the gm cars so any atf will work just fine.
As for when to add it, I put in a quart before I changed the oil but really doing it the way you mentioned as well will work
Hey guys howdy from Texas [emoji112] I have this annoying tick tick noise coming from my 2013 jku 3.6L penstar engine I’m pretty sure it’s a bad rocker, I just thought If there’s any oil additives to help reduce the tick noise you guys might of have luck with?
Thanks for your feedback
all thanks to that stupid oil filter housing thanks for messing up my rocker lifter
