Rubicon310
I've done some research on a few tire carrier/ rear bumpers for the jk and was wondering what the general opinion is in regards to this subject.
More specifically, what do you guys think of the cage style tire carriers that mount to the body vs the bumper with spindle that supports the tire carrier.
I personally like the look of the body mounted carriers such as the EVO, GenRight and the PSC but I'm a little concerned about the way they mount/ attach to the driver side. Some use a drop in pin, others use two small metal bumps that support the weight. Do they end up sagging when being opened? Maintenance required or constantly readjusting required?
The spindle mount bumper uses a spindle that looks extremely solid such as Crawler Conceptz and LOD.
Some require that you open the carrier then open the tailgate and others are a one piece open system.
The tire size that I will go with is a true 37.
Thoughts? Positive and negative as I will be pulling the trigger on something before the end of the week.
