Rear end issue
JKLIFE
Hey everybody, gotta a question. Took the Jeep in yesterday for an oil change... I know ok I know.... Could have done it my self but were currently in the middle of moving into our first home.... Anyway, the Mechanic raised the jeep up and I noticed a little issue.... Your thoughts! ImageUploadedByWAYALIFE1376415062.422946.jpg
Full view
Right Side full Extension
Left Side full Extension
They both measured the same width on the ground. But obviously at full extension I'm touching tire. What do I need to do to fix this?
What size do you think?
I have 1.5 on mine and they look and feel great , rough country has them for 60$ a pair. They are all the same now so don't let people talk you into the 150 a pair sets
I don't always wheel , but when I do I keep it tight......... Stay dirty my friends.
as mentioned above 1.5" is most common and the perfect size to clear the factory wheel studs. You can go smaller, but then you would be required to trim your factory studs down to fit under the spacer.
