Ratchet
Rachet's Rig
Let me preface this by stating that I have a pretty limited budget. Nearly all the work will be done by myself, as I find the time, money, and learn how to do so. This will be an exercise in "how to make it work, with the little you have."
My intent is to build a support vehicle for my other Jeeping buddies. Repair equipment, supplies, tools, things of that nature. To solve the potential problem of "Why didn't we bring a .... with us?"
After owning my Jeep for all of about...5 minutes, it became apparent that things were needed. So...I thought I'd create a build/reconstruction log.
Here's how she started:
Busted window, dry rotted tires, dying alternator, dented in driver fender....etc, etc, etc.
So, I hopped over to the local Pull-A-Part, and grabbed a new window. And banged on the fender until it straightened out somewhat. Which got me here:
But, then I found that the door hinge welds were cracking. Not surprised. Everytime the door opens, it swings too wide, and mashes the fender back in.
Also picked up a set of Grizzly wheels with tires, to replace the current 80's throwbacks. Even included a full size spare. Which introduced me to the newest problem.
Spent an hour, trying to break the lug nuts loose. Managed to get three of them off. Out of the whole set. So, I borrowed an impact wrench, and took another crack at it.
Two hours, a can of PB blaster, and a lot of cursing later....I was able to remove one wheel. The driver rear, the lugs will come off, but the wheel is fused to the axle. No amount of kicking, rocking the vehicle back and forth, etc was able to dislodge it. The passenger side, I was unable to remove any of the lugs. So, this is going to require a lot more force. And more cursing. And there is 5 lugs on the front wheel, don't worry. One just isn't chrome.
Next step, is to get the vehicle somewhere that I can work on it with more liberty.
