Quick question of front DS
kludwig13
Hey guys quick question, I am ordering a front DS and wanted to know if this is the one I need J.E. REEL JK 2012+, Front 1310 C.V. Heavy Duty Drive Line, 2/4 Door JER3112JK-24F. any info would be great.
You should check out Coast Drivelines too. Its what I run front and rear, they are very heavy duty. Personally either one would be a great choice. And the are both American made!
Paratroopers stay up longer!
THREAD RESURRECTION!!!
i have this same drive shaft and a 3" Enforcer lift. my installer said the driveshaft is too long, that it bottomed out and wouldn't bolt up.
i have a 2014
they say the DS will work from 0-6" lift i am wondering if i received the correct unit at this point ....
anyone have this one or the JER3112JK-24FM and can get some measurements for me ?
i have a 2014
Do you have an auto or manual?
I believe just by comparing part numbers that you got the manual shaft and the OP got a auto shaft.
i have a 2014
I believe the last two letters designate - front manual...
i have the manual version but i am grasping at straws here ... no one has measurements anywhere
wondering if they sent me one for an auto
Well I have a Auto Tranny so , What is the part number on the box ?
Also did you get the DS that came with both new yokes or the one that
Bolts to the stock yoke/flange....If there is the letter "F" only at the end
That would be for a Auto tranny....
all the part numbers are correct for my Jeep , but the drive shaft doesn't fit. i am thinking they put the wrong one in the box.
one i have has 2 new yokes and is the JER3112JK-24FM.
Well I think you should just give JE Reel a call and see if they can help you out.
I'll try and get a measurement off mine tomorrow if it will help out any.
Yeah I am planning on making a call. I have already sent an email but with new years I'm not going to get a response till Monday at the soonest
Ok so I went out Crawled underneath in the cold and snow.Grrrrrrr. Mines
Right at about 38" from U-join to U-joint ...
