protecting the shocks.
Hi
I just wonder if you need something to protect the shocks when you disconnect the swaybar. I mean, is the shocks strong enough to hold the whole front axle if one or two wheels are leaving the ground?
I´ve OME shocks if that matter.
You don't need anything. Your shocks in conjunction to your control arms and track bar will be able to hold up your axle fine.
Might be worth noting to zip tie the sway bar or hold it up (assuming it's a non rubi) cause if that sway bar points the wrong way could rub on something u don't want it to
