Jkusilverbullet
LOSER
Looking to upgrade to some 60s pretty soon. Been debating on whether to go with the Dynatrac PR60s or the Spicer Ultimate 60s. What do y'all run and why? Looking for some good comparisons!
Tons of breaks on the Dana ultimate 60s. Go ProRock for sure. Dynatrac made in the USA with US parts and workers with a patterned high clearance housing.
Knowing what I know now, and having purchased the Dynatrac Hardcore axle set (PR60 front/ PRO60 rear) I think I would have gone with the UD60s.
The front UD60 is basically a Dynatrac XD60 but with steel knuckles instead of aluminum. The UD60 has the same size U-joints as the XD60, and has the 10” ring gear like the XD60.
The rear UD60 is nearly identical to the Dynatrac PRO60, both are standard low pinion Dana 60 housings with 3.5” tube .5” wall, however I believe the UD60 has bigger wheel ends.
However after receiving the axles I would probably inspect all the welds on all the brackets and re-weld anything that is questionable, weld the tubes to the housing as spinning the tubes has been known to happen, and inspect the wheel ends. The quality control is pretty poor on these axles.
If you go with Dynatrac you most likely won’t have any issues if you just bolt them in.
My friend owns fusion, they are very stout axles also.Anyone know anything about Fusion axles? Came across them online but don't know anything about them.
Makes no sense. Dana $11880.00 with "The quality control is pretty poor on these axles."
Dynatrac $12990.00 with "If you go with Dynatrac you most likely won’t have any issues if you just bolt them in."
However after receiving the axles I would probably inspect all the welds on all the brackets and re-weld anything that is questionable, weld the tubes to the housing as spinning the tubes has been to happen, and inspect the wheel ends. The quality control is pretty poor on these axles.
I sold my UD60s and installed the 72.5 wide xd60/pr80. Fixed all my issues I had with steering rubbing on the uds and 40s.After having bought, extensively troubleshot, and wheeled them, I would not buy the Dynatrac Hardcore 60/60 axle set again.
I'm not sure I'd buy UD60's either given their reputation. I wish I could give you a recommendation, but I can't. If I was doing it all over, I'd spend the extra for custom width XD's, or custom something else.
I did state how I would address the quality control issue, but I guess people choose what they want to read
Believe me I read the whole thing. You said one has problems and one does not have problems. Then you said "If you could do it all over again you would choose the one with problems" You Never said WHY. Hence the sense of it all. But I guess people choose to think they are smarter than everybody else .:thinking:
I run them and have been very happy. 60/44 front hybrid and SF 60 rear. Great quality and customer service. I have seen their kingpin front and it is massive. And they have a FF 60 or 80 rear.
I thought you were running them but wasn't 100% sure it was both. Ever had issues bending flanges? I've done it twice now.![]()
