JayKay
Anyone have issues with their e-brake not holding intermittently? Sometimes I have to yank the handle all the way up in order for it to hold. Sometimes I only pull it halfway up and the handle gets tight and the Jeep doesn't roll. Every once in a while after I set the parking brake and release the brake pedal, I hear a loud "pop" from the rear. I know the sheathing on the cables is cut through slightly under the floorboard where they went through the bracket before the rear axle. I removed the bracket a while back, but I've had the problem before I installed the lift and removed the bracket. The issue has progressively gotten worse and my Jeep being a manual, I use the parking brake all the time. I plan on pulling the rear rotors off when I get the time to inspect the parking brake shoes and hardware. Just curious if anyone else has had this issue before.
