Oscar's No Build Thread
Finally finished my winch project today! I started with making some fairlead stiffeners from some 1/4" x 1 1/4" flat stock, cut them to 4" long on the cold saw:
Drilled some holes and painted:
The fairlead mounting went from this:
To this:
I don't think the bolts will pull through anymore! Then I painted the winch plate:
After that I cut the fairlead hole in my bumper facia with an ultra sonic saw (no pics ☹️), mounted the winch, bumper, vacuum pump, control box and ran all the wires:
Turns out it was just shitty enough outside to stretch the cable [emoji51]:
Hard to believe that I started to pull the dumpster [emoji33]:
Then a stop a Home Depot for license plate mounting hardware:
Done:
Time for some beers! [emoji481][emoji481][emoji481][emoji481]
Well done! Looks great! [emoji106] [emoji482][emoji482][emoji482]
Overall "build thread"
http://wayalife.com/showthread.php?26097-I-guess-it-s-the-quot-Super-Stocker-quot-build
Thanks! It took a long time, but I'm really happy with how it all turned out! Nothing like being able to say "I did that". [emoji41]
Damn buddy that is terrific! Awesome job! [emoji1303]
Thank you!
Nice! :thumb:
Thanks! It was a lot of work! Now I have to start thinking about the next project [emoji6].
Nicely done!
Thanks! You wouldn't believe how many times I considered just buying a plate for the top of the bumper [emoji33]. 30 hour mod and install means that I had my share of issues to deal with!
That is fantastic!
Thank you!
That's great work it looks amazing! I'm curious how you mounted the license plate cause I can't get an efficient way to keep mine on my winch and we need fronts here in NY
Thanks, I used 1 1/2" conduit straps and attached them right to the fairlead rollers with wing nuts for easy removal:
Looking down:
I tweaked them in a vice to make them "snap" onto the rollers so they stay put.
Looking good, keep up the good work!
Thank you!
I had some free time today so I started to build a rear seat recline kit. I had a bar of 7/8" x 1 1/2" x 18" Ductile Iron that had been Blanchard Ground on 4 sides just laying around the shop:
I cut 4 blocks to 2 5/8 long:
And set them under the seat legs to transfer the hole location, did some layout and punched the centers:
Afterward, I drilled a 1/2" Diameter hole through each one.
Then I cut the three rear spacers from 1/2" x 1 1/2" Steel Bar to 1 5/8" long and drilled a 1/2" Diameter hole through the center of each one.
Ready for painting. I replaced the 4 leg hex head screws with longer M12x65 SHCS and flat washers. I will post a before and after picture once the installation is complete.
Man! I'd love to have access to that equipment and "scrap" metal! Nice [emoji1303]
I'm a little spoiled having a 90,000 square foot facility and equipment available for my hobbies! Especially during the winter months. It's always nice to have a warm place to work on Oscar.
Finished the recline spacers and installed them this afternoon. Started with some paint for the spacers and oxidized the washers.
Then the tedious task of removing 8 seat bolts plus 2 nuts, adding the spacers and reinstalling.
Before (notice the headrest to window relationship):
After:
I think I cheated the photo a bit. It seems that the spacers offset the seat a good 3" and definitely made a difference! In all this project cost me zero dollars, but I wouldn't recommend it since that wouldn't be the case for most people. Kits are available from Amazon for $25. That's hard to beat if you had to pay for the materials and hardware.
Made a stop at Home Depot for a furnace filter and a bunch of other stuff made its way into my cart:
Found some painted, aluminum, expanded metal designed for rain gutter screens that were 5" wide by 36" long for less than $3 each. A bag of zip ties, anchors, and epoxy rounded out the purchase.
Cut the screens to 3 3/4" wide by 12" long. I need to peel away the 2 way tape from the 32 anchors and epoxy them into place:
Then zip tie the screen to the anchors. This is what the end result will look like when I finish tomorrow:
I think I like it!
