JudeinPa
I have been looking at several options to adjust my caster back to the normal range. Some of the options are buying a pre-set lower control arms such as the Teraflex Sport Arms or a set of the AEV Geometry Correction Front Control Arm Brackets.
The brackets seem to a good option as you gain both upper & lower adjustment which would put the front drive shaft at a better angle as well as help with the steering wander I have noticed with my 2.5" lift.
Buying a set of adjustable lower front control arms would give a better range of adjustment but don't know if I really need to with a small lift.
