piginajeep
The Original Smartass
So, on the gauge you got power going to it, the sending unit attached and then the ground all connected, right? On the sending unit, you have the power lead going to the gauge and the ground attached to the frame as well but still have no signal? I'm pretty sure all the old CJ gauges use a 73 oms empty/10 oms full setting so if you had a bad ground at the sending unit, your gauge would read full. Being that you have no reading, I'd have to say that you either do not have a signal coming from the sending unit or maybe you have a bad connection at the gauge. Do you have a an aftermarket gauge that you can test things against? If not, I might recommend it.
It's not getting a signal at the gauge. I've done the tests and the sending unit tests good. I should go back through and start testing connection again. The gauge is brand new.
