Ok first time got damaged my tire
tkkim
I just found some bolt stick in my tire.. I took it off, fortunately tire seems didn't
Get severe damage..
Do i have to check my tire? Or just fine?
Nitto trail grappler. 34"
ImageUploadedByWAYALIFE1366229476.902276.jpgImageUploadedByWAYALIFE1366229486.895944.jpg
Spray soapy liquid on the hole and look for bubbles. If it's leaking stick a plug In it, and your good to go!
^^^^ this all you need is a lil soapy water in the area and it will tell you if you have a leak or not. If it bubbles up, you have a leak! If it doesnt - well you dont! pretty simple. Although if you do have a leak, it is in a pretty easily repairable spot. Depending on where you bought them, you can take it to be repaired. OR you can stick a plug into it yourself and call it a day...
I just pulled a small nail out of mine yesterday, I spit on it and wiped it around a little and no bubbles. I hope yours is the same way.
