mackey
I have a 2013 JKU automatic with 20k miles. I have the EVO Protek skid system. The oil pan skid has been on about 6 months with no issues. A couple days ago I noticed oil drips on the garage floor. Looked under the jeep and the oil pan skid has a good amount of oil on it. The inside area near the drain hole is wet. The two bolts closest to the drain hole (see picture) have oil on them. I'm not quite sure where the leak is coming from. Here are some thoughts.
- I could re-torque the bolts around the oil pan. Will make sure not to over tighten.
- could tighten the drain plug. Doesn't appear to be the issue though.
- perform oil change. take off the oil pan skid and oil pan. Put in a new gasket, put pan and skid back on and hope it solves it.
- or being very careful, remove oil pan skid plate, leaving the oil in. Then tighten bolts and try to determine where the leak is coming from.
I already wiped off most of the oil from the skids but the pics will show the two bolts that have most of the oil on them.
