I have the updated/new Tuffy deck and it fits without any modification in combo with the RH4x4 C pillar kit. I send RH pics and install info so they could verify and help others with the info![]()
Which Tuffy part number?
Tuffy 326-01 Security Products Deluxe Security Deck Enclosure for 11-17 Jeep[emoji768] Wrangler & Wrangler Unlimited JK :thumb:
Tuffy 326-01 Security Products Deluxe Security Deck Enclosure for 11-17 Jeep® Wrangler & Wrangler Unlimited JK :thumb:
Yeah, I just installed the same one and didn't have to do much. I bent the metal on the deck a little bit back just in case there would be a rattle, but really it fit well without touching.
To be clear so we can update our site, you have the same one but had to make modifications?
I just can't decide if I should paint them black myself or have a shop color match them to the jeep.
This is how I'm leaning as well. Blue for the majority of the cage and black for the dash bar. I agree with you, I think having it match the factory bars will look good.Most body shop supply houses can mix up custom paint cans to match your factory paint. Just give them the paint code from inside the drivers side door jamb tag & they can do it. Did that with mine and it came out great.
I like them to match the factory roll bars. I did the dash bar in satin black though. I got 2 cans to do all of the front cage pieces but was on fumes at the very end. Be safe & get an extra if you go this route
C-Pillars in. Under the carpet and through the sport cage padding. Great product Rock Hard!
Be careful with the roll bar padding. It's easy to end up with too big of an X. Again, just start smaller than you think and work your way bigger as necessary.
Nice work. That turned out very clean. Did you run the bolts backwards through the tub? I installed mine per the instructions but I'm going to to reverse the bolts so the button heads are in the wheel well Seems like that substantially reduces the chance of tire damage at full stuff.
Nice work! I did the same thing with the wheel well bolts. Hit them with some bedliner that I have the wheel wells coated in and you can hardly notice them.Thank you! Yes, I did run them opposite of the instructions. I noticed in your Shark Tank thread you wanted to do that, so thanks for the great idea! :yup: I did throw some black VHT on after taking this pic.
