I'm in on rotors if you need commitments to get them to make a run.
Dave
Depending on the entire cost of the whole setup, I'm in too. Any ballpark idea yet what this mod will cost?
Consider it this way: My goal is to use off the shelf parts from other applications as much as possible. The trickiest part is an adapter (possibly) for caliper mounting, unless I find an OEM caliper with the right offset, bolt spacing, and other specs. But, here's a few market prices for 'in the running' parts:
Jeep J8 master cylinder: $80
Big rotors ( 14" x 1.25"), like 2006 Dodge Viper rotors: $65 each
Dodge Ram 2500 calipers: $50 each
So this comes to $310 bucks including a bigger bore master cylinder. These estimates may even be a touch on the high side. Costs not yet included are things such as boring the hub bore in the rotors to the right size for a JK, possibly drilling for a different bolt pattern, and cost to have a caliper mounting bracket made. I checked with a local machine shop and some ballpark costs for these services are:
$20 per rotor for drilling custom bolt pattern
$15 per rotor for custom hub boring
$75 per caliper bracket for material and labor (steel plate cut to dimensions and holes drilled, chamfered)
So, $310 + 20 + 20 + 15 + 15 + 75 + 75 = $530.
Doesn't sound too bad, if I can pull it off, for 14" brakes, huge calipers, master cylinder, custom caliper brackets, and all machining. What do ya think??
One thing I forgot to mention is that to truly do this correctly, I want the package to include REAR brake upgrades too... and so I have been researching that too...
Haha, after reading this thread, I didn't think for a moment that you were half-assing it. It really is a fantastic write up so far.
I agree! My starting point has been to see just how big we can fit, how close a fit I can find using off the shelf parts, and then if a caliper bracket needs to be made, pursue that. It actually quite fun and I'm so glad for the support. I feel that 14" rotors are gonna be doable even with stock wheels, which will be awesome!! I'll keep the info flowing!!
One other thing to think of with the "how big can I make fit" strategy is the cooling dynamics. Drilled/Slotted/Vented/Large mass/large contact surface/ all contribute to the cooling/heating. but if you get them so that they "just barely fit" you may run into cooling issues. Make sure you do not disrupt airflow too much in the quest to get the largest in.
The caliper will not allow the rotor to get so close to the rim that you would run into cooling issues, Especially since the rigs are lifted and lots of air flow under them. On a sports car I could see this being a issue. If one is worried about cooling you can always use a piece of sheet metal and make a vent to the brakes. This is what we did on auto cross cars.
