Here is a pick of my Arb twin setup under seat. I believe I used a 90degree fitting from the compressor and a 18" braided air hose to get me to the mounting location
It is a tight squeeze even with that 90degree adapter
View attachment 251029View attachment 251030
Hey! Thank you looks good. I thought I would just put an outlet there like you did too. Thank you
Hey Brick,
I am pretty much going to have the same set up as you. Are you using a 2" spacer in the rear like Kyle with your #59 coils?
For running the wire to compressor, besides removing the battery tray which is a total pain in the ass ( putting it back is even wore lol)
Is poking through the grommet and running the connectors through. Like I said before I managed to do this without splicing those compressor power and ground wires.
I am doing my 'genesis off-road' dual battery setup. I was OCD-ing about not sealing that grommet back up after cutting a big slit in it to run those compressor wires. I don't want any water in there. So I sealed it with some rtv silicone after running the wire for g screen.
The best thing about this battery Tray is that it still allows access to that grommet. So I can poke right though if I want to run something else through there. Without removing the tray again yay!! Lol
MY BUILT/REBUILD: http://wayalife.com/showthread.php?44123-Rebuilt-of-a-Billet-Silver-mall-crawler&p=859931#post859931
Two positive with decent size connectors and one negative, all that has to go through that grommet and connected to the battery. Took me a lot of cussing getting those through that grommet.
The slabs arrived!
What does anybody think of shiny rings? I have 1 no vote so far. I don't think the body color would look good, maybe raw aluminum and not polished? Like the old brushed centerline wheels
Should I replace the valve stems since they are used?
I just installed mine and I don't like the shiny ring. I'm going to plastidip the ring black.
New valve stems is easy to do. I had to and discount tire gave me the stems free since I don't want TPMS
Cleaned the threads on 120 bolts last night while watching Barrett Jackson Palm Beach
Holy crap... that must of been fun lol.
What you need all these bolts for?
Beadlock rings lol
Yup.. they cleaned up ok I think. New ones are $68 so I may just replace them, not sure yet
