My Jeep feels like I’m driving an ice skate at highway speeds
MtnJeep08
My Jeep feels like I’m driving an ice skate at highway speeds. I have a 2008 JKUR with a 3.5 inch lift and 37’s. I replaced the ball joints unit bearings tierod ends draglink track bar and steering stabilizer and had it aligned. The bumpsteer is terrible and I was told I didn’t need a draglink flip for that amount of lift. Will the draglink flip get rid of the bumpsteer and wandering?What am I missing? It’s a white knuckle drive at speeds over 55.
TrailHunter
The draglink flip should help.. also double check the toe.. it should be about 1/8” toe in... Caster should be around 4.2*... Also , everything may be really tight now because of the new balljoints etc... you could try removing the stabilizer until things wear in a bit... And tire pressure could be too high as well.
Upvote 0
Bumpsteer is where you hit a bump or hole and the steering wheel jerks in one direction. Wandering is more where the vehicle is just constantly drifting back and forth and you're constantly having to correct the steering wheel to stay straight. Which one are you experiencing?
Upvote 0
The answers I've seen are spot on. If I could guess, you might need a bit more caster. Flightiness at highway speeds is completely normal after a lift as tall as yours.
Upvote 0
MtnJeep08
I will check that and order the flip thank you
Upvote 0
MtnJeep08
Definitely getting both.
Upvote 0
