MT Baja ATZ
I have notice over the past couple of weeks my tires are starting to cup. It is more noticeable when they are wet. I am running the standard 32 psi in them for two reasons, one I do not know what psi is best and second the TPMS light stays on if they are below that. I do not have a programer to set the TPMS so I will deal with the light. Any suggestions?
R/
Will
I would try lowering the psi down to 28 or so Will. This will smooth out your ride and help with the wear. Another way to really tell the best tires pressure for wear is to do the chalk test. Chalk the tire at a certain psi then go for a short drive. Stop and check it. If there is still chalk then lower the psi and start all over again.
Hope this helps!
Sent from my iPhone
