JeepRubicon99787
Good question, I will need to check on that as I had the jeep dealer install the kit. I won't be able to check until day after tomorrow as she is currently in for a manufacturer fault found in the front diff, hence the reason I have the pull to the left.
The housing has a slight forward bend 2mm which is also the cause of the "leak".
