303Shane303
Just wondering if anyone has the Pro Comp 4" stage 1 lift kit and what you think about it...
That's the stage I am in now, researching...everyone's input on which lift you have and why you like/dislike it will be taken in to consideration.
I would prefer a bolt on lift because I will be doing the install myself, as my welding skills are limited. I hit the trails as often as I can, but like to be able to drive to the trails also. My Jeep is my toy, so no immediate rush on getting it done, but spring is here and I am ready to get out and play![]()
Is money a factor??? IF not evo bolt on coilovers and front and rear adjustable control arms and boom best of the best lol thats what im doing on my new jeep build when it arrives in the next coupld weeks!
(that is not everything you will need)
I would love to get the best of the best, but money is always a factor...I am trying to budget around $3500-$4000 for lift and 5- 35" tires.
$4500 is going to be tight for 5 35s and new rims ball park on them is about $2000 to $2500(depending on tires/rims) over 2.5 inch's you need drive shafts or maybe just one as its a four door! you need the lift and shocks as well as c gussets! can be done but you will deff have to put you research to the test!
At that price point, I might recommend an EVO Enforcer kit with draglink flip and running shocks other than the Kings that normally come packaged with it. A set of Rancho 7000's, 9000's or even Bilstein 5100's will get the job done well and for a lot less money. You should be able to do the whole thing including tires in the budget you have.
I'd suggest sticking to no more than 2.5-3" of lift if you're only getting 35's. You could then trim your factory fender flares for free providing you all the clearance you'll need and keeping your center of gravity nice and low, which will be better for you on and off-road. It'll also save you money on buying things like driveshafts.
You could certainly buy 5 brand new 35" tires, 5 wheels, a 2.5" lift kit w/ shocks, and gussets for under $3500.
Obviously, the EVO kit is going to be better than any other kit, but for a self proclaimed light/moderate off-roader, you may be able to come in $500-$1000 under budget going a slightly cheaper route. Then your new bumper or winch won't have to be "down the road".
Just a friendly suggestion.![]()
As mentioned previously, the EVO Enforcer 3" is certainly the way to go if you want the best of the best.
I will have to agree and disagree with you in some areas!! One if you never and i mean never ever (and i think its about 99% off jeeps wish they went bigger at one point) but if you think that then get the 2.5! If not i can tell you first hand that stage build are so expensive and when looked at in the end you could have had better soon for less! Research and know what you want to do be fore you even spend 1$ and be realistice on a time frame that fits your life! (took me a year of running stock to get every part i needed to build) DO IT ONCE, DO IT RIGHT!
