What axles comes on those? I'm guessing D30 since it's the Wrangler Sport with the Willys upgrade package. Comes with 3.73:1 gears.
Limiting factor on tire size is the axle and gears. 37" tires need a minimum of 4.88:1 gears to get the decent combination of highway and off road performance. Ideally you'd want 5.13 if better off road performance is your goal. Unfortunately the D30 axles don't do well with gears greater than 4.88 due to the and pinion gear . There's also the strength of the axle housing itself. D30s are not best suited for 37" tires. Don't get me wrong. There are a lot of people that run 37" tires on D30 axles and some that even run 5.13 gears and swear they have no issues. But, there are just as many that will share a horror story or two. 35" tires may be a better choice. You have more gear ratio options that increase the survivability of your axles and less weight on the axles.
Bottom line is, your choice. Good luck and welcome to Wayalife!
Sent from my SM-G930V using
WAYALIFE mobile app
