License plate relocation screws
Yep they're a tight fit. They may chip the paint a little on the way out if you're not gentle. If so just make sure you use a little touch up paint or something to prevent rust.
If that's where the hole is in the fender. Mopar has a delete plate that covers that hole entirely. I have it on mine however I forget the part number.
Yeah I got the poison spyder cover but the ps one has lil plastic knobs that go in the place where those metal things are :/
You can get a small flat head under one using your hand as leverage and pry it out. Just make sure you don't use the Jeep as leverage and yes, they will pop out with some force and will need the holes touched up after the clips pop off.
