LED Fog Lights Interfering With Radio
Boji
I recently installed some LED fog lights to go with my Trucklites however every time I turn them on my radio goes from clear as day to static, instantly. Has anyone had/heard of this issue? or know how to resolve the issue?
I've heard of similar issues, but not this exact application. Usually means a loose connection somewhere, even possibly the antenna. Make sure radio and new led lights are very tight, no loose connections. Also check that radio has proper ground.
Sorry hit the wrong button. Static on CB when 4 inch LEDs where on. Moved the LED ground to a different location. Solved the problem. Hope this helps
Alight when I get a chance I'll mess around with the grounds. The led's are hooked up to the factory wiring which is why I thought it was odd but we'll see what happens, i'll also check out the TIPM and see if the issue stems there or not
