Dr.McNinja
I put in my new JW speaker headlights after waiting patiently for the anti-flicker harnesses to arrive. Put them in, turned them on. Low beams were fine. Passenger high beam didn't come on. So then I swapped the lights, same problem. Swapped the harnesses with the lights, same problem, always the passenger. Put the old lights in, they were doing it to. I found that strange.
But since I don't use the high beams much, I figured I would go ahead and put in the new lights and figure out a solution. Went out for a drive, and suddenly the high beams both worked. But when I turned them off, the low beams didn't come back on. Playing with the switch didn't matter, but turning it off and on fixed that problem. The passenger high beam intermittently still doesn't work, so I'm not sure if this is a CanBUS problem, a wiring problem, or a clockspring problem (already replaced it once).
Anyone have any suggestions?
I don't recall the high beam not working on the right prior to the new lights, but again, I don't use them that often, so it's probably been a month or more. When I turn my right turn signal on, my foglights turn off, but that's not new and I assume that's the clockspring.
Lastly, here's a couple "from the driver's seat" comparisons of stock beams and my new lights. Had to seriously reaim the new ones.
