JKU Coile spring spacer lift
BumblebeeZA
Hi Guys,
I got spacers from a friend of mine and installed them last night.
The front spacer is 2.5' and the rear 1.75'.
My Jeep looks great and drives normally.
If I get longer shocks or shock relocation brackets, how much longer do I need to make the bump stops? Do I get 2.5' in the front and 1.75' in the rear?
Can I just make my own spacer between the current bump stops?
Heres how my JK looks now :D
EDIT: Sorry, heading should read "JKU COIL spring spacer lift" not "COILE" :)
With longer shocks you will want the brake line extension brackets or longer brake lines for the extra droop. Depending on tire size 2" or 3" bump stops would work
