Brute
Ohhh...... You are going to want to upgrade the driveline to a 1410 maybe even a 1480. With all that horsepower you might just twist a shaft off the starting gate with the skinny pedal to the the floor. JE Reel will make you custom shafts. Also 4.88's are kinda small for what you are doing, given you are going to run a 60 up front and 80 in the rear you might want 5.38's. Yes you adding horsepower to make up for less gearing, but if you don't tear through a 1350 driveshaft you might just rip the gear apart.
Are you sure the W5A580 Transmission is going to work? Are you upgrading the torque converter? That transmission is only rated for 428 foot pounds stock as is. You might have issues before even getting power to the driveshaft....
I can go on and on with other issues you are going to possibly have but let's start here.
Well, you are right....originally I was going with PR 60's front & rear...and a 6.4 hemi...I've copy & pasted a build sheet that was put together & modified with this original thought. The drive lines will be custom...as well as the four link rear & three link front suspension...coilovers & triple bypass shocks at each corner is a possibility...as far as the NAG1 is concerned, it is being completely rebuilt by Southern Hot Rod in LA for 1000 hp...
