So I already got denied by two dealerships. They even told me that it would cost 95.00 just to look at it and tell me what they have already said. So I found a local weld shop that will refill the plugs. While I'm at it, I've seen a few d30s with a bead going around the tube to the diff housing? Anyone recommend this and h e any comments on it? Keep in mind this is going to be a fix for a year or so until I can upgrade.
I'm not really sure why shops don't weld the tube entirely myself. But maybe there's something I don't know that could be affected. One thing though to remember, the inner axle seals are really close to that area so be careful with how much time you keep heat in that area so you don't damage the seals.
EDIT: Pumpkin is cast iron, tube is steel. Much more involved to weld cast iron.
I only brought it up because I was concerned about how they would handle the internals. Wasn't sure if they would just replace with a loaded d30 or a housing and transfer over my 4.56 set. At this point, I would rather not even deal with either dealership and just fix it myself. Then upgrade to a Fusion D60!Did they decline cause of the re-gearing and such?
honestly I wouldnt of even brought it up :S just been like... theres a problem there, fix it pleasebye
not the most honest thing but so is declining to fix on warranty if this was never touched by anything you did. unless im completely wrong and its directly related...
and if thats the case, i retract my comment and will shaddap!
So you guys are saying it's not supposed to look like this?
I'm going with NO
That's the overflow hole ;-)
