jknikos
Did it 5 hours ago. Getting the old one out was a pain in the ass :crazyeyes: The only way to get it unstuck was to move the wheel a little while another person pushed it down. Another issue is that when you finally put the new one in you have to pressure the tie rod on the pitarm with some way otherwise the castle nut moves with the rod and you cannot screw the nut. Moreover at the end I had to cut the nut on the top cause it has taller than the stock and made contact with the frame when I turned the wheel left.
