HELP! Can’t get fender wires unlocked
ScoobyCarolanNC
I’m doing the ACM under-fender ARB compressor install today and I can’t for the life of me get the turn signal wiring harness unclipped! What the hell man! I’ve watched 2 videos but can figure it out! Please help me here. It’s the same thing with the damn FAD wire. I can never get that one off.
kevman65
You've got the red lock pulled out, should be a little black button or tab you push on as you slide the two halves apart.
If it's been since never that it's been apart, you might need a small, straight (heterosexual) screwdriver to help get it separated.
kevman65
Tried the screwdriver, no avail. Where is the black tab?
Ahhh, the little red tab inside the black frame work.
Real bitch to get to if you have bear paws like me. I usually go in with 2 small screwdrivers, one for the tab the other to lever the connector apart.
