Rb1boxer_3
I used the 6 tons from harbor freight when I did mine and it was full droop. Next time I'm getting 12 Tons from work just to put it a Lil higher. My hands and knees were hurting.
			Hey man if you need to borrow a set let me know I can probably meet up and let you borrow my bigger ones
Budget boost weekend is back on! Thanks AnvilJK!
Great job so far! If you're having trouble getting the springs back in with the new coil spacers, then remove the axle side track bar bolt and then the axle will fall to the floor. The track bar is the droop limiter at that point. Keep it up!
Edit: never mind. I see you have them back in!
OK, got the front end all put together except for sway bar links that will come from back end tomorrow. Looks good except my bump stop on the passenger side is about 1/4" away from the bottom. Drivers side is about an inch. Ideas anyone? See previous post for pic.
I tried raising it up on the left to see if it'd pop in more but no luck.
