brodydez
I was driving really slow on the freeway the other day and I was close to the concrete wall. I had the top off and the windows rolled down and i heard what sounded like the wear bars on the front brakes squeaking a little bit. I work at a dealership so I put the Jeep up in the air and spun the front tires to see what the noise was. To my surprise the noise was coming from the back of the front diff. Sounds like the rear pinion bearing, but not sure. I pushed and pulled on the drive shaft to see if the pinion bearings were bad, but no movement. Do you think the noise is just the beginning of a bad bearing?
It doesn't look like overhaul kits are that expensive, but the labor in getting it out is going to be a pain in the ass.
Just a little info on what I have.
2007 JK with Dana 30 front and 4:10 gears with an Eaton locker.
Any help would be greatly appreciated. - Thanks!
