Flashpaq problems.
Mybadjk
So just swapped in the dynatrac 60. Trying to change the gears with my flashpaq to 5.38s and won’t update afterwards. Will go all the way up to 5.13s. I’ve read that if you have a manual it’ll only let you go up to 5.13s. Thing is I have an auto. I’ve tried all tunes and it won’t set any of the tunes and says that it failed.
Mattmc74
Send an email to superchips and tell them your problem. They will ask for some numbers on the back of your flashpaq. Then they will email you back with a link to fix your issue. I had a similar issue when i upgrade from the flashcal to the flashpaq. Aftwr the fix they did on their end my tuner worked just fine.
Sent from my LGLS990 using WAYALIFE mobile app
Slimebones
^^^This. They will work with you.
