USMC Wrangler
Several months ago I noticed some pulling (pass side on acceleration and driver side on decel) and thought I had a bent front lower factory control arm. Under the weight of the Jeep the pass side arm measured nearly 1/4" shorter than the driver. After I removed the factory arms I noticed the frame side bushing on the pass arm appeared much softer than all the others. The actual length of the factory arms, not under load, were exactly the same. This lead me to believe the bushing was the cause of this. I replaced the LCA's with Rock Krawler's and things have been good until last week.
A pull to the pass side under acceleration and during continuous driving reappeared. It is a slightly different feel than the pull I had before. Hard to explain online...
Before re-checking torque specs I grabbed all 8 arms, twisting and shaking them in the process. The front upper pass side arm has a lot of movement on the frame side. All of my paint pen marks were still lined up and all fasteners checked out. My camber is off on the pass side again, at about 6 degrees, no matter what I do.
Without knowing how to check the bushings for sure, is it likely this bushing is bad too? Is there a sure fire way to confirm a bad bushing? I've only guessed my other one was bad.
With only 34000 miles part of me wants to take it to the dealer, but another part of me thinks I should just go ahead and replace the upper arms too in order to avoid a repeat of this.
I'm only running an EVO leveling kit so I'm confused why this seems to be repeating. Everything else suspension/steering-wise is stock, except Rancho shocks. Has anyone else had these issues with the factory arms/bushings? What was your fix if you did experience the same?
Thanks in advance!
Thanks in advance!
