EVO suspension question.
mackey
I can't afford the Double Throw Down so I am looking at EVO's bolt on coilovers. Will EVO's high clearance long arm kit work with the bolt on coilovers? I also plan on running 60s, 1350s, ATX slabs, and 37s. Thanks.
You don't need to buy longer brake lines. They come with the bolt on coilovers. Also the draglink flip kit isn't needed, it's recommended but you don't have to run one.
I have asked the same question. In fact this is the set up Eddie is running on Rubicat.
This is what was recommended to me, http://www.offroadevolution.com/store/proddetail.php?prod=EVO-DD-LONGARM. This is the complete kit but you can get just the long arm kit. You will also need the Drag Link Flip, http://www.offroadevolution.com/store/proddetail.php?prod=EVO-DRAGLINKFLIP along with longer brake lines.
R/
Will
Does this kit include their high clearance brackets? Thanks for the help
I have not purchased my kit yet. Still waiting on SWMBO to authorize the purchase. Chris@OffRoadEvolution here on WAYALIFE will be better suited to answer the question. I was just passing on the info which was passed to me.
R/
Will
I've got that same setup on order.
You can't go wrong with the long arm and high clearance kit. I mean look at it!ImageUploadedByWAYALIFE1376356135.183352.jpg
Ken
It is not needed but it will make a big difference in your handling!
