As far as I'm concerned she should be happy it still works!! :clap2::bleh:
I went through a lot of pain to ensure it doesnt! :shock:
yes - FRONT D/S and Drag Link Flip kit
outstanding...and save up for later down the road to convert to LA or CO.
thanks again!
okay I am now officially confused... You know that the Double D kit is a LA (Long Arm) kit correct? Isnt that what we have been discussing?
If you are trying to lift your rig with 3" coils, you will need an entire lift, FRONT Adj Lower Control Arms, Brake Lines (or extension brackets) Bump Stops, etc. I might suggest the EVO MFG 3" ENFORCER kit which comes with all of that. But you WILL also need the Drag Link Flip AND a FRONT D/S.
^^This. If all you want is to run 35's with flat fenders, there really wouldn't be much point in going with a long arm kit. The EVO MFG 3" Enforcer kit is complete (except for the front driveshaft and drag link flip), but also doesn't include a bunch of crap you don't need. I've installed and driven a few of these kits. In my opinion, it's the perfect kit for people who want a quality setup that they can run hard but don't have the budget to step up to coilover/longarm setup.
Doesn't the double long arm kit come with a drank link flip?
Doesn't the double long arm kit come with a drag link flip?
One "can" upgrade to LAs from the enforcer and keep everything from the enforcer. Not the same as the high clearance LA upgrade, but still doable. Whether or not that's the best move, is up for further discussion. :thinking:
DLF is an add on.![]()
Yes it does...
As stated on the ORE website the full kit comes with drank link flip. The upgrade kit does not.
Here is the link.
https://www.offroadevolution.com/store/proddetail.php?prod=EVO-DD-LONGARM
Well then obviously I was ONLY talking about the upgrade. :cheesy:Good catch. :yup:
Any plans for EVO to make a 3.25" mid arm lift? 3" just isn't enough and 3.5" is too much. Thanks.
