The sways are definitely bolted on. Not sure how to check if it's electrically connected- I guess I could unbolt one end and see if it moves.
Here's the links- I took this pic just now.
IMG_5653
that sway bar link looks really short - is your sway bar level with the frame?
are your links the same length on both sides?
same with rear links?
It's level. I have the EVO drag link flip that raises the lower mount up about 3". I checked and everything is solid and bolted on. It tracks great on the highway, hands off at 70+mph. It's just whishy washy on uneven roads. I think it's just the softer springs. With the RK springs, the upper section is collapsed so you're riding on the mid-section of the coil. With the straight rate soft springs, they just keep squishing instead of stiffening up as the jeep leans.
