Stotch
I've been having a clunk in the front end that I've been hunting down for a few weeks. I narrowed it down to the sway bar today. I was putting new coils in and noticed that the sway bar was disconnected even though the EVO manual disconnect was all the way out. I took it out to inspect and this is what I found:
I took the rest of the sway bar apart and all of the gears are in good working order. With the sway bar off I experimented a bit with the disconnect knob and noticed that it didn't take much at all to make it disconnect by hand. I only had to rotate the knob once, then it disconnects with the knob still almost all the way out.
Above is a picture of it tightened in far enough to disconnect. I rotated it back out and it would lock up by hand, but I think the clunk I've been hearing is it slipping out. I'm thinking the spring is too long or the bolt on the other end of the knob is too long. The spring also looks like it has been rotating inside there a LOT, is that normal? Any thoughts before I call Quadratec or EVO?
