After you make the change can you please provide an update, I'll be installing the Enforcer 3" lift. Was your caster at 4 pre-installation and ended up at 4.7 with no adjustments? Did you install a new front shaft?
Factory is +4.2 deg. After installing a lift, your caster will be LESS than that and you'll want to return it back to stock. If you have more than 4.2, you added too much.
