JoeB-JKURX
Has anyone here used or even heard of Elite Ring and Pinion Gears? They are the least expensive R&P (for either Dana 30/44 or 44/44 - Rubicon) with master install kits that I've found at $575 and free shipping. I found them on e-bay and you can buy them there or at a store called Ron's Machining Service. They sound like any of the others but they are anywhere from about $100 to $400 cheaper than others I've found so a person might be a bit concerned how they could sell them so inexpensively.
Here's how they are described on e-bay:
Elite ring and pinion sets use the latest engineering and manufacturing technology to produce OEM quality gears at an affordable price. All Elite gears are machined from premium 8620 alloy steel, then heat treated to the strictest standards for maximum strength and durability. Elite gears then go through an extensive lapping process to assure easy setup, excellent contact patterns, and quiet operation. Elite gears include a 1-year warranty.
Elite premium master install kits are engineered per application and use only the highest quality components including Timken bearings. These kits are among the highest quality kits on the market today. Included are carrier bearings and races, pinion bearings and races, pinion seal, complete shim kit, ring gear bolts, pinion nut, crush collar (if applicable), threadlock, marking compound, brush, and gasket or rtv silicone.
