Has anyone added the over-the-axle piece from the Rockcrawler system to the Evolution Competition system? The drone from the comp system is damn near unbearable.
They use the same muffler so if you think the comp system drones then you might think the rock crawler system does as well.
But to answer your question, yes it will work. I have the rock crawler system on my 2 door. I took the axle pipe off and put the shorty pipe on when I moved out of PA. When I moved back to PA the over axle pipe went back on.
I'm not sure what this system looks like exactly but I added a resonator right in front of the muffler on my MBRP system & it took 90% of the drone out & quieted it down at idle significantly.
Which resonator did you use?
Sent from my iPhone using Tapatalk Pro
I used this flow master one from amazon, it was more expensive than some of the others but had good reviews.
https://www.amazon.com/gp/product/B00548VUPW/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
System looks just like this...
https://wayalife.com/showthread.php...petition-Exhaust-System-Installation-Write-Up
Gracias! You happen to have any pics?
Won't be an issue and will knock the tone down a solid chunk too.
:beer:
Thanks! I'm actually going to try and add one of your bullet mufflers behind the existing muffler first. I'd like to keep it dumped before the axle. Should know Saturday when it gets here and I can get it installed...
Glad you posted this, i'm about to do the same thing and was wondering where I would place the hanger.
I also have the over axle tube but if this quiets it down enough all the better :thumb:
I don't know if the system got louder or my tolerance got lower with age...
Hey ya young'un in the mustang, put a muffler on that thing! :cheesy:
Got it all installed today. I ended up moving the muffler hanger bracket that comes with the kit to the back side of the evap canister. I had to notch the evap bracket to get the hanger in the right spot so it would line up with the dump that comes with the comp kit.
So with a bullet muffler and a clamp I was able to make it work. I may eventually take it somewhere and have it all welded up, but it’s working for now.
View attachment 347929 View attachment 347928 View attachment 347927 View attachment 347926
